Knowledge Base Article
How to compile the discontinued Nios® II processor IP core in future Quartus® Prime Software?
Description
The discontinued Nios® II processor IP core is rendered unavailable in the Quartus® Prime IP Catalog after Last Time Shipments. Interested parties are encouraged to refer to the  Nios® II Processor Product Discontinuation Notice (PDN2312).
The recommended action is to implement Nios® V processor IP with equivalent functions in new designs. Alternatively, the discontinued Nios® II processor IP core supports design compilation with pre-generated IP files.
Resolution
On the Nios® II hardware flow:
In the last Quartus® Prime Software version (that supports Nios® II processor IP core),
  • Open the Platform Designer system.
  • Click Generate HDL.
  • Convert the Nios® II processor IP Core into a generic component.
    1. Select the processor.
    2. Navigate to the Component Instantiation tab.
    3. Select Implementation Type as Blackbox.
    4. Click Apply.
  • Save the Platform Designer system
The system is ready for regeneration and recompilation in the latest or future Quartus® Prime Software (that does not support Nios® II Processor IP core).
Note: Nios® II processor license is required in the Quartus® Prime software.
On the Nios® II software flow:
Nios® II Software Build Tools for Eclipse are last supported in,
  • Quartus® Prime Pro Edition Software version 23.4, and
  • Quartus® Prime Standard Edition Software version 23.1.
Users must continue Nios® II software development (Nios® II Board Support Package and Application projects) in these software versions or earlier.
Please take a look at the requirements and limitations to implement the workaround.
You are required to,
  • Preserve the Nios® II processor .ip file and its generated RTL folder (it should have the same name as the Nios® II processor .ip file).
  • Preserve the SOPCINFO file.
  • Configure the Quartus® Prime Software.
         Navigate to Assignment > Settings > Board and IP Settings > IP regeneration policy, select Never regenerate design files for IP cores.
         Upon Generating HDL, disable Clear output directories for selected generation targets in Generation > Output Directory.
         If quartus_ipgenerate command is applied, remove --clean or –clear_ip_generation_dirs.
You are limited to,
  • Fixed generic Nios® II processor component. Due to the preserved IP files, any changes made onto the Nios® II processor are not reflected.
  • Fixed IP cores or connections to the Nios® II processor. This is to maintain the host-agent services between the Nios® II processor and other IP cores.
  • Fixed Nios® II SOPCINFO files for BSP files generation. This is constrained by the above limitations.
Updated 3 months ago
Version 2.0
