Knowledge Base Article
How do I view the bottom portion of the ALTLVDS_RX MegaWizard Plug-In window?
Description
In the Quartus® II software versions 10.0 and later, the ALTLVDS_RX MegaWizard™ Plug-In window size is fixed. If your monitor's vertical display resolution is not high enough, you cannot view the bottom portion of the window.
Resolution
To work around this problem, use a display resolution with a vertical height of at least 900 pixels.
This problem has been fixed beginning with the Quartus II software version 11.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
