Knowledge Base Article
How do I upgrade IP cores at command-line in the Quartus II software version 14.0?
Description
In the Quartus® II software version 14.0, use the following command to upgrade a single IP:
quartus_sh –ip_upgrade –variation_files <ip_path/name_of_ip>.<v/vhd> <project>
To upgrade multiple IPs at the same time, use the following command:
quartus_sh –ip_upgrade –variation_files “<ip_path/name_of_ip1>.<v/vhd>; <ip_path/name_of_ip2>.<v/vhd>” <project>
This is documented in the Quartus II Handbook chapter Upgrading IP cores[PDF]
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
