Knowledge Base Article
How do I program MAX® II, MAX® V, or Intel® MAX 10 devices with the real-time ISP feature using the quartus_jli command?
Description
You can use a JAM STAPL Format File (.jam) file or Jam Byte Code (.jbc) file with the quartus_jli command to program a MAX® II, MAX® V, or Intel® MAX® 10 device with real-time ISP feature.
Resolution
To create a Jam or JBC file, follow these steps:
- Choose Programmer under the Tools menu in the Intel® Quartus® Prime Software, or start the stand-alone Programmer.
- Display the JTAG chain of your devices by clicking Auto Detect, opening the Chain Description File (.cdf) file or adding devices manually.
- Add your target Programmer Object File (.pof) to the MAX II, MAX V, or Intel MAX 10 device to program.
- For Intel MAX 10 devices, ensure the Enable real-time ISP to allow background programming when available option is selected.
- Choose Create JAM, JBC, SVF or ISC file under the File menu.
- Type a file name and a file path to store in File name box.
- Choose JEDEC STAPL Format (.jam) or Jam STAPL Byte Code 2.0 (.jbc) from the File format list.
- Click OK.
To program the MAX II, MAX V, or Intel MAX 10 device using the Jam or JBC file with real-time ISP feature using quartus_jli, use the following commands respectively:
For Jam file
quartus_jli -aPROGRAM --enable=DO_REAL_TIME_ISP <file name>.jam
For JBC file
quartus_jli -aPROGRAM --enable=DO_REAL_TIME_ISP <file name>.jbc
Related Articles
Updated 10 months ago
