Knowledge Base Article
How do I map the 8 available transceiver VOD settings in the Stratix V GX IBIS-AMI model to the 64 available settings in the Custom and Low Latency PHY MegaWizards, and Transceiver Toolkit?
Description
You can map the 8 available transceiver VOD settings in the Stratix® V GX IBIS-AMI model to the 64 available settings in the Custom and Low Latency PHY MegaWizards™ and Transceiver Toolkit using the table below.
| IBIS-AMI VOD Setting | PHY VOD Setting |
| 2 | 10 |
| 4 | 20 |
| 6 | 30 |
| 7 | 35 |
| 8 | 40 |
| 9 | 45 |
| 10 | 50 |
| 12 | 60 |
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
