Knowledge Base Article
How do I include a C file in my Nios II C software project?
Description
C2H doesn’t support generating accelerators from C files.
There is a work-around which will enable you to call your accelerator(s) from a C program which involves moving the functions you wish to accelerate from a C source file to a C source file.  Once your functions are in a C source file, the C2H compiler can effectively “see them” and convert them into hardware accelerators.
There are some additional steps necessary for mixing C and C functions (and files).
The GNU tool-chain supports the calling of C functions from C programs (and vice versa) through a well defined methodology of explicit assertion.   The way this works is that, from your C program you tell the compiler which functions should be call as C functions- instead of C .  This operation is done through the use of the extern “C” syntax within the C source file.
Some examples of the extern “C” syntax in action are as follows:
  1. Calling C function from C program
Setup:  You have a function void bar(void), which lives in C source file “bar.c” that you want to call from the C source file “foo.cpp”.
Solution:  Add this to the top of “foo.cpp”-
                extern “C”void foo(void);
  1. Calling C functions from C program
Setup:  A collection of functions which lives in C source file “bar.c” that you want to call from the C source file “foo.cpp”.
Solution:  Simply add braces around the group of functions at the top of the extern statement in “foo.cpp”-
                extern “C” {
void foo(void);
int foo2(int number);
int foo3(int number1, int number2);
  1. Calling a C header from a C program
Setup: You have a whole collection of C functions (or a library) in a file called “bar.c” that you want to call from your C program “foo.c”, and you really don’t want to list them individually through procedure #2 (above).  You do have a header file for “bar.c” called “bar.h” which declares the interface to the functions.
Solution: The extern statement also works for header files… In the file “foo.cpp”, use the extern statement to add the header file-
                extern “C” {
                                #include “bar.h”
Which methodology is best to use with C2H?  When using the C2H compiler, it is recommended that a user “isolate” the function for acceleration into its own file, so using the first example is the best approach for accelerating functions with the C2H compiler.
Updated 11 months ago
Version 3.0
