Knowledge Base Article
How do I connect the detected_rate and detected_rate_in signals from the Serial Digital Interface (SDI) MegaCore?
Description
The detected_rate signal is available when you generate the SDI MegaCore® in Transceiver Only configuration.
The detected_rate_in signal is available when you generate the SDI MegaCore as protocol only block configuration.
Resolution
These signals are used to detect whether the video format is 1/1.000 or 1/1.001. Connect the detected_rate signal to the detected_rate_in signal.
These signals are used in conjunction with the rx_video_format signal to differentiate the video format.
Updated 11 months ago
Version 3.0
