Knowledge Base Article
How do I access the EPCQ configuration device on the Cyclone® V GT FPGA Development Kit?
Description
The MAX® V device design provided with the Cyclone® V GT FPGA development kit does not allow you to access the EPCQ configuration device that is fitted to the kit.
Resolution
To enable configuration using the EPCQ device, reprogram the MAX V device with this .pof  file: MAX V device EPCQ pof file and set the MSEL pins to enable Active Serial mode configuration.
You can also use this VHDL file: MAX V device EPCQ source code to update the MAX V device design provided with the kit.
Related Articles
Updated 4 months ago
Version 5.0
