Knowledge Base Article
How can I re-host my DS 5 AE License?
Description
DS-5 Altera Edition licenses are 'FIXED' and node-locked. If you need to transfer your license to a new machine, you must ask ARM to do the 're-host'.
However you can also setup your license so its more portable.
Resolution
To rehost your license follow the steps below:
- Consult the following FAQ: ka3660
- Go to: silver.arm.com/licensing/ and select ‘Request License Rehost’.
- Work directly with ARM to get a new license.
You may want to consider making the new license portable. You could lock it to a portable USB-ethernet adapter or portable PCMCIA network card as permitted under the licensing terms and conditions documented in FLEXnet for ARM Tools License Management Guide .
Updated 1 month ago
