Knowledge Base Article
How can I implement multipliers larger than 36 bits in Stratix™ device digital signal processing (DSP) blocks?
Description
Multipliers with widths greater than 36-bits must be implemented using more than one DSP block. You must specify the width using the LPM_MULT megafunction and the Quartus® II software will automatically make the appropriate connections between the DSP
Updated 11 months ago
Version 3.0
