Knowledge Base Article
How can I check if a .sof (SRAM Object File) file contains a Signal Tap instance?
Description
You can use the jtagconfig utility to identify if a Signal Tap instance is available by displaying the available services on the JTAG interface.
To find out if Signal Tap is available in the .sof file, perform the following actions:
- Program your board with the .sof file
- From the command line run utility 'jtagcofig --debug' . If Signal Tap is present you will see a line starting with Node Signal Tap # listed under particular device.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
