Knowledge Base Article
Fragments and UndersizePkts Counters Issues
Description
This errata affects the Triple-Speed Ethernet MegaCore function.
You may observe both etherStatsFragments and etherStatsUndersizePkts increment when Fragments are received. etherStatsUndersizePkts should not increase when the Fragments are received.
This issue affects variants of MAC function with statistic counters.
Resolution
This issue has no workaround.This issue is fixed in version 12.0 of the Triple-Speed Ethernet MegaCore function.
Updated 11 months ago
Version 3.0
