Knowledge Base Article
For designs that include ALTMEMPHY, the <memory controller name><random string>_pin_assignments.tcl file generated by Qsys (Beta) does not assign correct pin names
Description
For designs that include ALTMEMPHY, the <memory controller name><random string>_pin_assignments.tcl file generated by Qsys does not assign correct pin names. Running the Tcl file immediately after generation results in incorrect pin assignments.
Resolution
After you generate your design and before you run the Tcl script, open the Tcl file and change the line
set instance_name “<memory controller name>_<random
string>” to set instance_name “<memory controller name>”.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
