Knowledge Base Article
For DDR2 and DDR3 SDRAM Controller with UniPHY, SOPC Builder Designs Suffer Low Efficiency
Description
If you use SOPC Builder to instantiate a DDR2 or DDR3 SDRAM Controller with UniPHY IP core, you may find your design has low memory efficiency.
Resolution
To work around this issue, use the MegaWizard Plug-In flow to instantiate a DDR2 or DDR3 SDRAM Controller with UniPHY IP core.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
