Knowledge Base Article
FIR Compiler Functional Simulation Model Is Not Generated
Description
When you try to generate a FIR Compiler functional simulation model, one of the following two error messages appears:
“Cannot run program “<Quartus II IP installation>\fir_compiler\lib\ip_toolbench\netlist_writer.exe” (in directory <project directory> create process error=14001 this application has failed to start because the application configuration is incorrect”
or
“IP Functional Simulation Model Creation Failed. The following error was returned: Error: Node instance “fircore” instantiates undefined entity “<instance_name>_st” File ...”
and the functional simulation model is not generated.
All FIR Compiler variations.
FIR Compiler simulation model is not generated.
Resolution
To avoid this problem, perform the following steps:
  1. Download the appropriate version of Microsoft Visual C 2008 SP1 Redistributable Package (x86) for a 32-bit machine or (x64) for 64-bit Windows XP.
  2. Double-click on the vcredisk_x86.exe or vcredisk_x64.exe file you downloaded.
  3. Follow the instructions.
If you are prompted to uninstall or repair, click Repair.
Updated 11 months ago
Version 3.0
