Knowledge Base Article
***Fatal Error: Segment Violation at 0x8
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 23.1, you might see this error when changing the Trigger Conditions in Signal Tap.
Resolution
To work around this problem, use a previous version of the Quartus® Prime Standard Edition Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
