Knowledge Base Article
Fatal Error: Access Violation; Module: quartus_map.exe Lock in use: 9, (atm_amerge)
Description
Due to a problem in the Quartus® II software versions 12.0 SP2 earlier, you may see this error when compiling your design if your design has only one partition.
Resolution
A patch is available to fix this problem for the Quartus II software versions 12.0 SP1 and 12.0 SP2. Download and install the appropriate patch from the links below:
- Quartus II software version 12.0 SP1:
- Quartus II software version 12.0 SP2:
This problem is fixed beginning with the Quartus II software version 12.1.
Updated 4 months ago
Version 13.0No CommentsBe the first to comment
