Knowledge Base Article
Fatal Error: Access Violation at 00007FFEACC49E5A
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition Software version 21.1, you might see this error when adding finite state machine nodes in Signal Tap.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Standard Edition Software version 21.1. Download and install the patch from the following links:
This problem is fixed starting with the Intel® Quartus® Prime Standard Edition Software version 22.1.
Updated 8 months ago
Version 3.0
