Knowledge Base Article
Failed to launch MegaWizard™ Plug-In Manager. PLL Intel® FPGA IP v18.0 could not be found in the specified library paths
Description
In the Quartus® Prime software version 18.0, when you want to open the MegaWizard™ for editing, you may see error message "Failed to launch MegaWizard™ Plug-In Manager. PLL Intel® FPGA IP v18.0 could not be found in the specified library paths".
Resolution
To work around this problem,
1) Locate the .lst file of the missing IP in your Intel® FPGA program directory. For example, for the missing PLL, locate "pll_wizard.lst".
In the case of Windows:
Windows <installation_directory> \ip\altera\altera_pll
In the case of Linux:
Linux <installation_directory>/linux64/ip/altera/altera_pll
2) Change the text.
"<ALIAS>Altera® PLL v18.0</ALIAS>"
to
"<ALIAS>PLL Intel® FPGA IP v18.0</ALIAS>
Updated 3 months ago
Version 2.0
