Knowledge Base Article
Ethernet 10G MAC failed ncsim/vhdl simulator elaboration stage
Description
When you generate an Ethernet 10G MAC with either of the following settings enabled in the GUI and targeting VHDL, the generated design will fail the elaboration stage when compiled with NCSIM simulator.
1. Enable Time Stamping = "1"
2. Speed = "1GBps/10Gbps" or "Multi-Speed 10 Mbps - 10 Gbps"
Resolution
To work around this problem, use the following command to generate simulation scripts that will elaborate correctly.
make-ip-simscript --spd=<spd filename> --compile-to-work
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
