Knowledge Base Article
Error:xxx: The current value "" (2970) for parameter "PLL output frequency" (output_clock_frequency) is invalid. Possible valid values are: "" (3000.0:12500.0). . Rule(s): output_clock_frequency.
Description
You may see this error when implementing the SDI protocol datarate of 2970 Mbps when using the Arria® 10 Transceiver CMU PLL IP in Quartus® Prime Standard edition version 15.1.
Resolution
This problem will be fixed in a future version of the Quartus Prime Standard edition software.Updated 2 months ago
