Knowledge Base Article
Errors in the Configuration Pins Summary for Intel® Cyclone® 10 LP Devices
Description
Issue 523215 : Chapter 6 Configuration and Remote System Upgrades, section 6.3.3 Device Configuration Pins, version 2017.12.22
Table 47. Configuration Pins Summary for Intel® Cyclone® 10 LP Devices has the following errors.
- The configuration pin name of nCSO/FLASH_nCE is incorrect. It should be nCSO.
- The Input/Output column of CLKUSR incorrectly says Output. It should be Input.
- The Input/Output column of nCEO incorrectly says Input. It should be Output.
- DEV_OE pin is missing. The location is Bank 5. It is an input pin, is not a dedicated pin and is powered by VCCIO. The configuration mode is Optional.
Resolution
| Bank | Configuration Pins | Dedicated | Input/Output | Powered By | Configuration Mode |
| 1 | (incorrect) nCSO/FLASH_nCE => (correct) nCSO | - | Output | VCCIO | AS |
| 6 | CLKUSR | - | (incorrect) Output => (correct) Input | VCCIO | Optional |
| 6 | nCEO | - | (incorrect) Input => (correct) Output | VCCIO | Optional, all modes |
| 5 | DEV_OE | - | Input | VCCIO | Optional |
Updated 27 days ago
Version 3.0No CommentsBe the first to comment
