Knowledge Base Article
Error(16184): Port "devclrn" does not exist in primitive "dffeas" of instance "gen_dff[0].dd" on Intel® Arria® 10 FPGA designs
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2, you might see this error during compilation with the Design Netlist Infrastructure (DNI) flow enabled. This error might be seen on Intel® Arria® 10 devices using the HDMI Intel® FPGA IP.
Resolution
To work around this problem, follow these steps:
- Download the bitec-hdmi-tx-tmds.zip file.
- Unzip the file to obtain the bitec_hdmi_tx_tmds.v file and put it in the project directory.
- Add the following assignment to the end of the QSF:
set_global_assignment -name VERILOG_FILE bitec_hdmi_tx_tmds.v -library altera_hdmi_1970
This problem is fixed beginning with version 22.3 of the Intel® Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 3.0No CommentsBe the first to comment
