Knowledge Base Article
Error When Generating Simulation Model Using MegaWizard Plug-in Manager
Description
When you use MegaWizard Plug-in Manager to generate a simulation model for the IP core, you may get an error message if the Quartus II software installation directory has empty spaces in the directory path. The Quartus II software displays a warning message similar to the following:
Error: add_fileset_file: No such file <Quartus II installation directory path>/ip/altera/ethernet/altera_eth_10g_mac/list_of_files.tcl while executing "add_fileset_file list_of_files.tcl OTHER PATH list_of_files.tcl" (procedure "testbench_proc" line 2) invoked from within "testbench_proc dd"
Impact all configurations.
Resolution
To avoid this issue, do not type empty spaces in the directory name when you specify the installation directory for the Quartus II software.
This issue will be fixed in a future version of the 10-Gbps Ethernet MAC MegaCore function.
Updated 11 months ago
Version 3.0
