Knowledge Base Article
Error: System integrator FAILED
Description
Due to a problem in the Intel® FPGA SDK for OpenCL™ compiler, you might see the following error when using the incremental compile option with a design that contains host channels:
Resolution
To work around this problem, do not use increment compile with designs that contain host channels.
Updated 11 months ago
Version 3.0
