Knowledge Base Article
Error: Sub-system: SDR, File: /quartus/sld/sdr/sdr_tx_trigger_gen2.cpp, Line: 840
Description
Due to the problem in the Quartus® II software version 13.0 SP1 and earlier, you may see this error when adding signals to the SignalTap™ II Logic Analyzer using the Nios® II plug-in.
Resolution
A patch is available to fix this problem for the Quartus II software version 13.0 SP1. Download and install patch 1.10 from the appropriate link below:
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 4 months ago
Version 5.0
