Knowledge Base Article
Error Running Nios II Project: Downloading ELF Process failed
Description
If the Nios II processor’s cpu.data_master port is not connected to all program memories (memories to which the .elf file is downloaded) the software project fails to run on Nios II hardware.
Failure to connect cpu.data_master to all program memories is a design error that the Nios II SBT does not detect.
Resolution
Connect cpu.data_master to all program memories.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
