Knowledge Base Article
Error: quartus: xcb_xlib.c:82:xcb_xlib_unlock: Assertion ‘c->xlib.lock’ failed.
Description
If your Linux operating system uses the X protocol C-language Binding (XCB) library (libxcb), the Quartus II software might fail to start with an error similar to the following:
quartus: xcb_xlib.c:82:xcb_xlib_unlock: Assertion "c->xlib.lock" failed.
Resolution
Upgrade you Linux distribution to the latest version or, if your Linux distribution uses libxcb version 1.1, run
export LIBXCB_ALLOW_SLOPPY_LOCK=1
before running the Quartus II software version 11.0.
Updated 2 months ago
Version 2.0
