Knowledge Base Article
Error: [Qsys] Component not found or could not be instantiated
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 18.1 and 19.1, you may see this error when using the Quartus® Prime default IP generation flow.
Resolution
To work around this problem, uncheck the Use multiple processors for faster IP generation dialog box in the Generate HDL step of Platform Designer.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
