Knowledge Base Article
Error message : "Error: Optimizer FAILED -dbg-info-enabled --grif --soft-elementary-math=false --fas=false --wiicm-disable=true "kernel_top.1.bc" -o "kernel_top.kwgid.bc"
Description
Due to a problem with the FPGA SDK for OpenCL™ software technology, you may see this error after a long compilation time. This is caused by a large number of storage operations to undefined elements performed by the h_updating_graph_mask_buf_0 and h_graph_visited_buf_0 arrays functions.
Resolution
To fix this problem add the following lines in the kernel_top.cl file:
*** 22,30 ****
  #pragma ACCEL interface
variable=k depth=1
    bool stop;
    do {
-     bool h_updating_graph_mask_buf_0[1000000];
-     bool h_graph_visited_buf_0[1000000];
  //if no thread
changes this value then the loop stops
      stop =
false;
  //omp_set_num_threads(num_omp_threads);
--- 22,30 ----
variable=k depth=1
    bool stop;
  bool
  bool
    do {
  //if no thread
      stop =
false;
This problem will be fixed in a future release of the Intel FPGA SDK for OpenCL
Updated 11 months ago
Version 3.0
