Knowledge Base Article
Error in IP Compiler for PCI Express with Two Virtual Channels
Description
Hard IP variations of the IP Compiler for PCI Express with
an Avalon-ST interface that have two virtual channels are missing
the rx_st_empty1 signal that indicates whether the rx_st_data1[127:64] data
bus holds valid data.
Resolution
This issue has no workaround. You can generate your IP Compiler for PCI Express variation to use a single virtual channel.
This issue will be fixed in a future version of the IP Compiler for PCI Express.
Updated 2 months ago
