Knowledge Base Article
Error-[ILWOR] Incorrect Logical Worklib or Reflib. The incorrect logical lib is "altera_gpio_core10_ph2_2210". Please check your Synopsys setup file.
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3.1 and earlier, you might see this error or a similar one when simulating a subsystem packaged IP, such as EMIF and Nios® IPs. This error occurs when using the simulation scripts generated by the ip-setup-simulation utility. The problem is that the ip-setup-simulation utility does not include the hierarchical information of the internal IPs packaged in the top-level IP in the generated simulation scripts.
Resolution
To work around this problem, use one of the following methods:
- Use the quartus_ipgenerate utility: quartus_ipgenerate <project name> [<options>]
- Use the qsys-generate utility: qsys-generate <.qsys system file to generate> [<options>]
Refer to the following command line example for the quartus_ipgenerate utility:
quartus_ipgenerate top --simulation=verilog
Refer to the following command line example for the qsys-generate utility:
qsys-generate top.qsys --quartus-project=top --rev=top --testbench-simulation=verilog
Type quartus_ipgenerate -h or qsys-generate -h to see all the available options and the corresponding descriptions.
Refer to 7.10. Generate an IP Component or Platform Designer System with quartus_ipgenerate and 7.2.1. qsys-generate Command-Line Options for more information on how to use the quartus_ipgenerate and qsys-generate utilities.
This problem will be fixed in a future release of the Quartus® Prime Pro Edition Software.
