Knowledge Base Article
Error: exec failed with errno=(2) message "No such file or directory"
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.2 and earlier, you might see this error when creating the simulation testbench with the Signal Tap Create Simulation Testbench (beta) flow. This error only occurs in the Ubuntu environment.
Resolution
To work around this problem, follow the following steps:
- In Ubuntu Terminal, type vi .bashrc
- At bottom of .bashrc file, include this command export PATH=<quartus_installed_directory>/qsys/bin:<quartus_installed_directory>/quartus/bin:$PATH
- Insert your own installation path in the command
- Save the modified .bashrc file by typing: wq
- Reboot the Operating System (OS)
- Re-open Ubuntu Terminal, type quartus to launch the Quartus® tool
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
