Knowledge Base Article
Error ELBREAD_0081 mgc_axi_slave.sv (195): Design unit mgc_common_axi instantiated in fpga_interfaces.mgc_axi_slave not found in searched libraries
Description
Due to license restrictions, you will see this error when you simulate a Platform Designer system with Hard Processor System (HPS) using Riviera-PRO.
The HPS instance is represented by the Mentor AXI BFMs instantiated in generated simulation environment for each HPS AXI interface enabled in the system.
Resolution
To work around this restriction, use Mentor ModelSim or another supported simulator to verify your HPS-based design.
For information about supported 3rd party verification tools, see the latest AXI BFM documentation.
More details on the Mentor Graphics* AXI Verification IP Suite web page.
This information is now contained in the Intel® Quartus® Prime Pro Edition User Guide: Third-party Simulation web page.
Updated 11 months ago
Version 3.0
