Knowledge Base Article
Error Compiling alt_ddrx_bank_timer.v With Riviera-Pro for ALTMEMPHY-Based Interfaces
Description
This problem affects DDR, DDR2, and DDR3, ALTMEMPHY-based products.
ALTMEMPHY-based designs created with a version of the high-performance controller
(HPC II) earlier than 11.0,. may fail to compile alt_ddrx_bank_timer.v in Riviera-Pro.
An error similar to the following may appear:
Error: Riviera-Pro Error: # SLP: Fatal Error: alt_ddrx_bank_timer.v (528):
Memory or vector object expected (current_state[parameter]).
Resolution
There is no workaround for this issue.
This issue will not be fixed.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
