Knowledge Base Article
ERROR: CL_INVALID_KERNEL_NAME
Description
If you run vector_add opencl example design on Intel® Programmable Acceleration Card with Intel® Arria®10 GX FPGA . An error may occur as follows:
  [root@localhost vector_add]# ./bin/host
  Initializing OpenCL
  Platform: Intel(R) FPGA SDK for OpenCL(TM)
  Using 1 device(s)
  pac_a10 : PAC Arria 10 Platform (pac_a10_f100000)
  Using AOCX: vector_add.aocx
  Context callback: Specified kernel was not built for any devices
  Failed to create kernel
  Segmentation fault (core dumped)
Resolution
You should check if your initialization script file (for example the init_env.sh file) has the following enironment variables set:
CL_CONTEXT_COMPILER_MODE_ALTERA=3
CL_CONTEXT_COMPILER_MODE_INTELFPGA=3
To work around this problem, you should unset the environment variables, and try running the host again.
Updated 11 months ago
Version 3.0
