Knowledge Base Article
Error (184057): Fitter cannot read the .mif db/<name>.mif
Description
Due to a problem in the Quartus® II Software version 12.1 and later, you may see this error message when you have multiple revisions in your design. The Quartus II software incorrectly deletes the incompatible databases when a new revision is selected and you will see a message that the Memory Initialization File (.mif) is missing during fitting.
Resolution
To work around this problem, do the following:
  1. Delete the db and incremental_db folders
  2. Open the main revision
  3. Switch to the desired revision and compile
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0
