Knowledge Base Article
Error (178018): Channels in the bonded channel groups containing the following must be placed in contiguous locations. If CMU PLLs are used, gaps must be left for the transmit PLL channel.
Description
You may encounter the following Fitter errors if you are compiling a design with the 4 channels of a XAUI PHY placed across two Arria® V device transceiver banks in Quartus® II 13.0.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Standard Edition Software version 13.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
