Knowledge Base Article
Error (175020): The Fitter cannot place logic IO_LANE that is part of Generic Component ed_synth_phylite_s20_0_example_design, to which it is constrained, because there are no valid locations in the region for logic of this type
Description
Due to a problem in the Intel® Quartus® Prime Standard Edition Software version 20.4, you may encounter a fitter issue while placing REFCLK sharing between IO48 tiles within the same banks in PHY Lite Interfaces Intel Agilex® 7 FPGA IP.
Resolution
These errors are due to a hardware limitation. The fitter didn't check the REFCLK location constraint because it assumes the REFCLK needs to be in the same tile.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
