Knowledge Base Article
Error (175001): The Fitter cannot place 1 LVDS_CHANNEL, which is within Altera LVDS SERDES dpa_rx_x1_wo_pll_altera_lvds_170_q4dwfni
Description
You may see this error if you implement an Arria® 10 “N” channel DPA LVDS design using a single 1 channel instance stamped multiple times in external pll mode.
Resolution
This configuration of single instances stamped multiple times is not supported using external pll mode. If an 8 channel design is required using external pll mode then a value of 8 channels must be selected in the Altera LVDS SERDES IP.
Updated 1 month ago
Version 2.0
