Knowledge Base Article
Error (169026): Pin oct_rzqin is incompatible with I/O bank {bank}. It uses I/O standard SSTL-135, which has VCCIO requirement of 1.35V. The requirement is incompatible with bank's VCCIO setting or other output or bidirectional pins in using VCCIO 2.5V.
Description
This error might happen if you are trying to implement DDR3L SDRAM interface using UniPHY based controller IP. DDR3L SDRAM interface uses SSTL-1.35V I/O standard, the oct_rzq pin also requires the SSTL-1.35V I/O standard.
Error (169026): Pin oct_rzqin is incompatible with I/O bank {bank}. It uses I/O standard SSTL-135, which has VCCIO requirement of 1.35V. That requirement is incompatible with bank's VCCIO setting or other output or bidirectional pins in the bank using VCCIO 2.5V.
Resolution
Make the following assignment manually in your project QSF file:
set_instance_assignment -name IO_STANDARD "SSTL-135" -to oct_rzqin
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
