Knowledge Base Article
Error (14703): Invalid internal configuration mode for design with pre-initialized eram
Description
Due to a known problem in the Quartus® II software version 14.0, you may get this error when compiling a design that targets a MAX® 10 device that supports configuration modes with memory initialization. The design utilizes internal memory blocks.
Resolution
To work around this problem, use the following Intel® Quartus® II Settings File (.qsf) assignment
set_global_assignment -name ENABLE_ERAM_PRELOAD ON
This problem was fixed in version 15.0 of Intel® Quartus® software.
Updated 11 months ago
Version 3.0
