Knowledge Base Article
Error (14024): Parameter "oscillator_divider" of instance "crcblock" has illegal value "1" assigned to it. Possible parameter values are: 256, 128, 64, 32, 16, 8, 4, 2
Description
If you set the oscillator_divider parameter of a WYSIWYG CRC block to 1 in a design that targets an Arria V, Cyclone V, or Stratix V device, compilation might fail during synthesis with the following error:
Resolution
To prevent the error, specify a valid oscillator_divider parameter value (256, 128, 64, 32, 16, 8, 4, or 2)
Updated 11 months ago
Version 3.0
