Knowledge Base Article
Error 129001 Compiling HPS Component
Description
When compiling an HPS design, you might see an error message similar to the following:
Error (129001): Input port DATAIN on atom \
"hps_qsys:u0|hps_qsys_hps_0:hps_0|hps_qsys_hps_0_hps_io:hps_io|
hps_qsys_hps_0_hps_io_border:border|hps_sdram:hps_sdram_inst|
hps_sdram_p0:p0|hps_sdram_p0_acv_hard_memphy:umemphy|
hps_sdram_p0_acv_hard_io_pads:uio_pads| \
hps_sdram_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs| \
altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|
extra_output_pad_gen[0].config_1", which is a cyclonev_io_config
primitive, is not legally connected and/or configured
This error might appear if you add the HPS component to your top-level system by adding the source .qsys file to the Quartus II project.
Resolution
Use the following standard Qsys system generation flow:
- In Qsys, generate the HPS component subsystem.
- Add the resulting .qip file to the Quartus II project.
Alternatively, upgrade to v13.1.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
