Knowledge Base Article
Error (11692): Design cannot be fitted into HSSI strip. 2 pma_aux_blocks under reference clocks set: dup_3ch_tx_pll_refclk[0]
Description
Due to a bug in the Quartus® II software version 13.1.3, you may see the Fitter error above when compiling for Arria® V devices.
Resolution
This is a known bug in Quartus II software version 13.1.3. To work around this, you can do either of the following
Updated 4 months ago
Version 4.0
