Knowledge Base Article
Error (11176): Alt_sld_fab.splitter: Port ir_in_0 is not fully defined after elaboration
Description
Due to a problem in the Quartus® II software version 14.1 and later, you may see this error in designs that include a Quartus II Exported Partition File (.qxp)Resolution
To work around this problem, create a text file named quartus.ini in your project folder and add the following command:
- sci_use_legacy_sld_flow=on
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
