Knowledge Base Article
Error (10228): Verilog HDL error at lvds_rx_lvds_rx.v(49): module "lvds_rx_accum" cannot be declared more than once
Description
You may see this error in the Quartus® II software versions 13.1 and later when implementing the ALTLVDS_RX IP with external Altera_PLL and Dynamic Phase Alignment (DPA) enabled with more than two channels in Arria® V devices.
Resolution
To work around this, first, complete the steps for implementing ALTLVDS_RX and ALTLVDS_TX with external PLL mode as described in the related solutions.
Then, after running Analysis and Synthesis in the Quartus II software, copy the lvds_rx_lvds_rx module from the contents of the file db/lvds_rx_lvds_rx.v into the lvds_rx.v file.
This will add the module lvds_rx_lvds_rx into the lvds_rx.v file.
Ensure all occurrences of rx_dpaclock is 8 bits and all connections of rx_dpaclock are correct.
For example,
 .dpaclkin(rx_dpaclock),
instead of:
 .dpaclkin({8{rx_dpaclock}}),
Related Articles
Updated 11 months ago
Version 3.0
