Knowledge Base Article
Error (10002): Can't open VHDL or Verilog HDL file
Description
When compiling a design in the Quartus® II software, you may experience the following error message:
Error (10002): Can't open VHDL or Verilog HDL file "{Hierarchy}/{file_name}"
The error is caused when the hierarchy path exceeds the 256 character path limit.
Resolution
To work around this problem, shorten the hierarchy path below the 256 character path limit.
Updated 11 months ago
Version 3.0
