Knowledge Base Article
Erroneous Timing Failures in Designs Containing Both UniPHY and ALTMEMPHY Instantiations for External Memory Interfaces
Description
Designs containing both UniPHY and ALTMEMPHY instantiations may encounter erroneous clock failures during timing analysis.
Resolution
The workaround for this issue is to open the UniPHY <core_name>_report_timing.tcl and <core_name>_pin_map.tcl files
in an editor, and make the following change in each file:Locate
the traverse_to_ddio_out_pll_clock function name, and
append the numeral 2 to the function name, making it traverse_to_ddio_out_pll_clock2.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
