Knowledge Base Article
Embedded Audio Signal Not Stable
Description
When you transmit an embedded audio in an SDI instance, the embedded audio detected switches repeatedly between locked and unlocked. The AES input module causes the embedded audio signal to be unstable.
This issue affects all SDI Audio Embed configurations that use the AES input module.
The embedded audio in the video signal may not be stable.
Resolution
None.
This issue has been fixed in version 11.0sp2 of the SDI Audio Embed MegaCore function.
Updated 2 months ago
